krivanj
Jun 09, 2024Explorer
Coleman heat pump will automatically switch to propane if the temperature difference between the thermostat setting and ambient inside air is four or more degrees. I have to turn the thermostat on and quickly run the thermostat so that it is 3 or fewer degrees from ambient.
Having RV issues? Connect with others who have been in your shoes.24,381 PostsLatest Activity: Apr 17, 2026
