jodeb720's avatar
jodeb720
coleman Mach - Temperature Differential model 8333e856
Afternoon all,
As I sit here in the campground, sweating (as it's in the mid 90's), My trailer AC unit doesn't seem to be keeping up with the expected cooling temperature delta.
I've been told (or read maybe onhere) that the delta between intake and exhaust should be 40 degrees.
I removed the cover for the intake (it's both ceiling vented and has vents that open on the output side, held my thermometer in the air blowing down and it was about 62 degrees. I then put the thermometer down on the counter while I resealed all the cracks and crevasses with aluminum tape - I figure every little bit helps, right?
Anyway, the temperature in the trailer is 82 degrees.
I checked the air filter - and I cleaned it the last time I was out - and yes, it's still clean.
I expected a temp delta of 40 degrees and I'm only seeing 20.
Model 8333e856
Coleman Mach
I'm assuming it's a 13,500 btu unit -
So - my questions:
1. Is a 20 degree delta acceptable or am I expecting too much?
2. Am I missing anything?
Thanks in advance!
Josh
Having RV issues? Connect with others who have been in your shoes.24,199 PostsLatest Activity: Feb 18, 2025
