Compression ignition Gas Engine
Mvander
clicky
Just read an article in the March 14' Car and driver about huyndai's experimental "gasiel" engine. Interesting read although the link is to a different article on the same engine.
Thoughts???
55 FEET OF FAMILY FUN!
2014 F150 HD
2015 Grey Wolf 29DSFB
5 REPLIES 5
gandude
LOL,
Nayan Engineer (yes, that’s really his last name), a powertrain engineer with Hyundai.
Nayan Engineer, engine engineer.
Tahoe 21WTB Toyhauler
06 Dodge 3500 SLT, QC, LB, 4x4, 5.9, auto 370's
03 Kawasaki 360 Prarie
03 Kawasaki 300 Bayou
79 Honda XL 250
12 Honda XR 650
down_home
The idea is not new. It requires heavier components, as a diesel does. Injection pressure needs not be as high because the fuel is not as viscous.
Temps will be higher than diesel requiring better alloys in pistons etc or stainless capped pistons etc.
Operating ranges will be narrower as a diesel usually is, imo. They can engineer high performance versions but they will be heavier still.
The idea of the design is not performance but economy, of fuel consumption only. Cost, of everything, including fuel, including taxes will be much higher.
wa8yxm
Well, I know of diesels that used a gasoline system for pre-heat, Those have indeed been out for a long time,, Drove one myself over 40 years ago for a bit (It was a skip loader).
RLS7201
Always wondered why that technology wasn't considered for civilian use. The US military had been using multi-fuel compression ignition engines for over 50 years.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
mlts22
If they can engineer something innovative, more power to them. This type of engine will work very well with turbos.
I'd like to see an engine go the next step and be able to run on either gasoline or diesel with the ECM doing all the work in getting the right mixture into the combustion chambers.
