BFL13
Apr 30, 2019Explorer II
Mex, my highest (adjustable) voltage charger can do 16.5v at most at 45 amps (PowerMax PM3 45LK)
I see para 5.6 here, so that looks like fun! Yipes. I could give it a whirl. (Don't really want to, but if required....)
http://lifelinebatteries.com/wp-content/uploads/2015/12/6-0101-Rev-E-Lifeline-Technical-Manual.pdf
Do you suppose the 8D has been like this ever since I got it a year ago, or did it go this way recently for some reason?
What will happen in the near future if I pretend I never found this out, and carry on as though everything is "just fine"?
EDIT--I don't have a way to maintain constant charge current at 5%
of 24 hr (assume typo for 20 hr?) capacity = 12.5amps. If the charge current is around that amount by a fluke, I can keep it at 12.5 by raising the voltage as the amps taper until I reach max charger voltage 16.5, but then amps will taper. I remember something about light bulbs to help with that, but long gone in memory how that works.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
