โDec-18-2017 12:47 PM
โDec-18-2017 09:22 PM
kerrlakeRoo wrote:
ktmrfs, my numbers were based off what I got from the company website, it may be high due to them going by the maximums, I dont know.
My pressure has been raised twice by the docs, DW's has half a dozen times so I would assume those pressure settings change power consumption. The bricks also show the watt ratings at 12 volts as 60 for mine and 90 for hers.
If your number is a measured number, and his unit is similar, he could use a group 27 battery and a 50 watt solar panel and would have a surplus. phone, laptop ets charging would all be helped.
โDec-18-2017 08:23 PM
โDec-18-2017 04:09 PM
โDec-18-2017 03:39 PM
โDec-18-2017 03:36 PM
โDec-18-2017 03:32 PM
kerrlakeRoo wrote:
DW and I both use machines, mine is a CPAP without the humidifier, (appears to use about 4 amps per hr) and hers is a BIPAP with the humidifier (uses as much as 7 amps per hr) Both are Phillips units capable of running straight from 12 volts.
If you wear the mask 8 hrs the energy consumed can be as high as 50 amps per night. for a single machine. So how big is you house battery? can it carry that usage without totally depleting the battery?
โDec-18-2017 03:27 PM
โDec-18-2017 03:18 PM
beemerphile1 wrote:
Respironics operate on 12vdc and can run directly from a battery with the correct cord.
โDec-18-2017 03:16 PM
mileena wrote:
I have been prescribed a CPAP machine for Obstructive Sleep Apnea. How do I run this while traveling if I don't have a generator or battery?
โDec-18-2017 03:05 PM
mileena wrote:
Thanks! Yes mine has that battery "brick". It is a Philips Respironics DreamStation. I will go to their site and buy a battery. I've read that they only last 4 hours or so, without the humidifier. We'll see.
โDec-18-2017 02:53 PM
โDec-18-2017 02:35 PM
โDec-18-2017 02:34 PM
Tiger4x4RV wrote:
CPAP.com shows a shielded DC (12V) cord for the Dream Station available for $29.95. https://www.cpap.com/productpage/pr-dreamstation-shielded-dc-cord.html
I have an older Respironics System One machine and have used the CPAP.com DC cord for it for years in the RV with no trouble. It uses a cigarette lighter type plug and the regular 12V wiring.
Read the manual on your jump starter carefully. Some of them cannot handle the sustained load of running a CPAP. Here is a link from the Stanley website for the unit shown in your photo. I'm a librarian, good at looking things up, and not an electrician, so I'll leave it to you or your electrical pro to interpret what this manual says about the sort of load your Dream Station will create.
You may need the humidifier. Humidity here in SoCal has often been in the single digits lately and my respiratory system has really appreciated having that humidifier.
