Makin__Do's avatar
Makin__Do
Converter - Easy Question
I have a Progressive Dynamics PD9245C and I'm installing 2 GC 6 volt batteries in series. I've always had 12 volt batteries in the past and used the PD to convert/maintain my batteries. Since many of you seem to prefer 6 volt GC batteries I would assume that many of you also have PD converters. So, am I safe using PD or do I need a different type converter? I checked PD's web site and FAQ's, but they do not address the issue.
  • wa8yxm's avatar
    wa8yxm
    You have what I consider to be the very best converter made and it is designed specifically for a pair of Six Volt Flooded wet cells.. The only "Upgrade" possible would be a 9260 instead of a 9245 but the 9245, which will recharge slightly slower..May add a bit to the life of the batteries.. I think you will be very happy with it.
  • Basically any 12v RV converter will work on 6v or 12v batts. A pair of either are basically the same voltage, and the same AH capacity.
    But, a PD converter works better ! :)
  • Thanks all. Just wanted to be sure. Didn't want to tell the wife I fried $600 worth of new batteries.
  • Properly wired those 6V batteries will be well maintained by that PD converter
  • I have used the very same combo, PD 9245 and 2 6 volt batteries, for more than 4 years and it works great,no problems at all.
  • Two 6VDC batteries in series are pretty much a large 12 volt jar, assuming both batteries are of similar capacity and such. You shouldn't have any issues using your PD converter.
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 21, 2025
