KATOOM
Jul 09, 2014Explorer
Convertors and HEAT
I thought I'd share something. I always noticed that my convertor fan was running a lot when plugged in to shore power and the large storage compartment which it sits in was warm as well. Also, my battery charging voltage numbers never seemed to be what I have read they should be. For some time I thought my convertor was garbage or the wiring to and from the convertor were too small which was contributing to my inadequate battery charging issues. So I did some research and saw that its not uncommon for convertor fans to be running. But then in saying that, while recently packing up to go out for a week I had the storage compartment which houses the convertor open for days on end. Strangely even in the hot triple digit weather I noticed that the convertor fan hardly ran and my battery voltage numbers seemed strangely higher than normal. Well that got me thinking and I decided to try something. So I got an exterior vent (just like the one on my battery compartment) and drilled a 3" hole in the trailer wall and installed that vent opening directly next to the convertor. I cleaned things up and vacuumed around the area and the convertor sides and now the convertor runs as it did when the compartment door was open allowing free flowing air to pass by the unit. Obviously it seems to me that there was some overheating issues going on here and the unit didnt like running hot because my charging voltage numbers are way better and way more consistent than they have ever been. I'm curious to see how this plays out over time, but I thought I'd let anyone know who cares.
