gat75
Jan 29, 2017Explorer
Coolant chg on 2009 D/A
Owner's manual on my 2009 D/A states that coolant should be changed 5 years or 100,000 miles, (whichever comes first). I only have little over 80,000 miles, (even though I bought it new in Nov 2009).
I normally do as much maint as I can on my vehicles. The dealers all want to "flush"the system, (however they say that this does not get the bulk of the coolant out of the system).
There is no drain plug on bottom of radiator, (as it use to be). Looking for any tips on doing what looks to be a messy job. The fender well needs dropping on the pass side just to access the bott radiator hose. I have also heard that this engine has drain plugs on each side of the block. Supposedly, one is located behind starter.
Anyone on forum changed their coolant, if so, how did you do it?
Thanks in advance for your help!
