richy2ExplorerSep 04, 2017Correct psi ?I recently took delivery of a Dynamax rev motorhome. The label on the pillar shows 65 in front 80 for rear. When I checked, the psi was 80 all around. What should the correct psi be for this vehicle. ...Show More
Kayteg1Explorer IISep 04, 2017To be precise, you should weight axles, or preferable wheels and go to tire manufacturer site for inflation chart per load.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,211 PostsLatest Activity: Mar 11, 2025
Related Contenttire psiPSI rating variablesWhat PSI for tires?Correct sizePSI when using higher load range tires.
