Oct-16-2018 06:31 PM
Oct-17-2018 01:50 PM
Oct-17-2018 01:32 PM
theoldwizard1 wrote:
Off the top of my head, I know of no AGM battery charger that monitors battery temperature.
Oct-17-2018 01:25 PM
Big Katuna wrote:
All these batteries will ever do is start the genset and run lights (all led) occasionally.
Oct-17-2018 12:37 PM
Oct-17-2018 12:13 PM
Oct-17-2018 10:10 AM
theoldwizard1 wrote:MEXICOWANDERER wrote:
Golf car size AGM batteries are not superior versus regular BCI size batteries.
Trojan T105-AGM hold about 5%-10% less energy than the FLA T105.
FLA can tolerate higher charging temperature (which usually comes along with higher charging rates).
Oct-17-2018 09:25 AM
Big Katuna wrote:BFL13 wrote:Big Katuna wrote:
2005 Freightliner Fleetwood, Xantech Freedom 458 inverter/charger connected to four 6V golf cart batteries, which need replacing.
I would like to replace these with either two 6V or two 12V maintenance free AGMs.
We rarely boondocks, have a gas option fridge and if we need to use the microwave, will start the genset.
What we DO do is leave the RV plugged in all the time with AC on low, which fries the GC batteries. I have the watering system installed but still manage to forget and they get dry.
Are there direct replacement size wise for GC batteries?
If you are nearly always at full hook-ups, all you need is a simple 12v house battery to power the inverter/charger.
You are right that 6s don't like to Float very much. Xantrex even has/had their 3-stagers with the option to turn off the third stage for that reason.
It is the high SG of 6v batts which makes them not so good for floating them. Lower SG batts are better for floating, but have less capacity and discharge rates.
If you do want an AGM go for a type that is low SG and meant for floating such as those UPS types. But why spend the money? You could get a single simple sealed flooded starting battery like for a car to meet your requirements looks like.
Thank you. I think this is the correct choice for me. My sealed engine batteries are on year seven and start the old C7 just fine. Getting ready to replace them on general principals.
I’ll buy four instead of two
Oct-17-2018 09:17 AM
Oct-17-2018 09:07 AM
Oct-17-2018 09:04 AM
AGM batteries don't like a lot of amperage
when charging. they can't handle the heat.
Just get some deep cycle batteries.
Where in the world did you get that idea?
AGM is famous for safely accepting tremendous charging current safely. Except for tele communications special purpose batteries.
My single regular group 31 Lifeline chomps 101 amperes without even getting warm. CHARGING is done in a controlled manner.
Oct-17-2018 08:35 AM
Oct-16-2018 08:54 PM
Oct-16-2018 08:50 PM
Oct-16-2018 08:36 PM
