HiTech
Jun 12, 2013Explorer
Create dump load with a schmitt trigger and controller?
I'd love to have a way to harvest the load wasted when a PWM solar controller moves out of bulk mode and starts PWM cycling the connection to the panels, without significantly impacting the primary controller in its mission.
One simple answer might seem to be a second controller wired in parallel to the panels, but with a high voltage threshold such that it is not powered until the voltage is sufficiently high, such as a voltage near Voc.
Alternately possibly a switching circuit that is triggered by the downside state change of the charging pulses out of the first controller might be used to switch on the input of the second controller (including a capacitor wired across the second controller input to smooth the input pulses).
Is there an inexpensive way to harness the unused solar power from the solar panels between PWM charging pulses?
Jim
Jim
