phemens
Sep 21, 2017Explorer
Critique proposed solar battery upgrade
Currently have a Jayco hybrid (Jayfeather 26L) but moving to a Denali 5th wheel in the spring (2012 DE324LBS).
Currently have 4 Trojan T125’s with 600 watts of solar, with a Kisae 2000 watt pure sine inverter, we primarily dry camp.
Plan for ‘new’ trailer is to upgrade batteries and solar. Batteries are 5yrs old, serviceable but nearing end of life. Would like to go with 1000 watts solar, and possibly 6 x Crown 6CRV 220 AH AGM batteries. I’ve heard that AGM handle heavy loads better than FLAs. Typical use of inverter now is coffee maker morning and evening, plus TV and occasional limited use of microwave. My end goal is to have enough capacity to run the inverter pretty much any time (i.e. not switch on/off all and ideally run the fridge on 120 during the day to reduce LP use and leverage excess solar during the day.
Inverter is wired to batteries with 4/0, plan for solar is either a single 60A converter with 24v panels or 2x 30 (already have them, but willing to upgrade that too, one is MPPT, the other isn’t.
Got time to plan, so thoughts?
