opnspaces
Sep 15, 2019Navigator II
Not on a charger, but I did have a battery explode in my Toyota Camry when I turned the key to start. I unfortunately don't remember what happened to the battery as far as if only the caps blew off. But I do remember the whole car shuddering when it went off. Fortunately this happened in my driveway so I was able to quickly douse the engine compartment with copious amounts of fresh water from the garden hose and prevent any acid damage.
As far as charging in your TH; An RV is far from airtight and I can't imagine any appreciable buildup of hydrogen. With an automatic maintainer I would probably let my batteries charge. But I would also shy away from the $4.99 Harbor Freight tenders as I've had a couple of those fail on me. One stopped charging and the other was overcharging at something like 16 volts.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
