lhaeb
Dec 05, 2015Explorer
Dash AC thermostat replacement
I have a sticking AC thermostat. The dash AC does not come on until I tap on the thermostat with the handle of a screwdriver. My diagnosis is that the thermostat is bad. I do not see how to change the sensor tube with out taking the whole evaporator case out. A local dealer says he will do it but the bill will be over $1000. There has to be an easier way to change the part without taking the evaporator out. I was thinking about cutting a hole in the case but then I am still not sure if I can install the sensing tube. Do any of you replace the part and how did you do it? I have placed this message on another forum but no replies. Thanks
