nohurrynoworry's avatar
Feb 26, 2017
Dashboard Warning Lights, 94 Winnabago
Hi to all:
My continuing effort to get my recently purchased 94 Winnabago (Chevy chassis) back to all systems go. Recently had a high beam head light out, replaced it, works fine now but did not resolve another issue that I hoped it would, that the blue high beam indicator in the center of the dashboard does not come on when high beams are on. Putting a flashlight behind the dashboard I can light up the blue high beam indicator along with what appears to be a red check gauge indicator to the left of it and a red battery indicator to the right, none of these ever light up when ignition is keyed on or the high beam headlights are engaged. It looks to be a solid printed circuit behind these warning light indicators, no apparent bulbs, no wires, so I don't know how this warning light unit works. This is probably a condition not normally experienced but I thought I would ask. May require an automotive electronics shop to trace this issue.
  • The indicator is lit via a fiber not directly from lamp. On mine, there is a row of small lamps across bottom of the dash assembly. You will need to look at each one. I think mine was third from the left side.
