Gjac
Apr 06, 2016Explorer III
pianotuna wrote:To be more specific if you refer to the nice picture that Roy posted for the 6v battery set up, you would connect your pos wire from your inverter to the +12v wire on your first 6v battery and your neg wire on your inverter to the wire marked ground on the second battery in his picture.
Use the positive from one six volt and the negative from the other six volt.
