โApr-12-2014 05:46 PM
โApr-16-2014 01:08 PM
โApr-16-2014 10:01 AM
Shomemule wrote:
I guess my biggest challenge is securing the new framing to the aluminum siding. I can remove the old from the siding with a sawzall but I'm not sure how I'll secure the new since the studs are screwed from the outside in. Construction adhesive is one alternative but I'm not sure how well it will adhere to the aluminum.
โApr-16-2014 09:37 AM
Shomemule wrote:Most aluminum siding on Rv's is not fastened to every framing member. If you have a bad corner section, remove the trim rail that covers the corner, remove staples or screws that fasten the siding to the studs. Remove siding by removing screws or staples that fasten it to studs, top plate, and bottom sill.westend wrote:
You can do it and don't let the armchair engineers tell you not to. I'm assuming throwing away an otherwise serviceable RV is not the way you want to proceed.
Look at the build thread in my signature line, the Cowboy/Hilton. I replaced frame and flooring and it is all pictured there. If you have a particular question, let it fly or shoot me a PM.
Thanks westend. I guess my biggest challenge is securing the new framing to the aluminum siding. I can remove the old from the siding with a sawzall but I'm not sure how I'll secure the new since the studs are screwed from the outside in. Construction adhesive is one alternative but I'm not sure how well it will adhere to the aluminum.
โApr-16-2014 08:16 AM
โApr-16-2014 07:27 AM
โApr-16-2014 07:10 AM
โApr-16-2014 06:08 AM
โApr-13-2014 08:40 AM
โApr-13-2014 04:57 AM
mlts22 wrote:
Unless you are in love with -that particular camper-, I'd say forget it. One can spend the same amount of money and buy a new or used camper in decent shape... and then spend time camping, not replacing moldy wood.
If one wanted a DIY project to learn on, it is an idea, but it will be very time consuming.
โApr-12-2014 11:25 PM
โApr-12-2014 08:02 PM
โApr-12-2014 07:58 PM
โApr-12-2014 07:56 PM
โApr-12-2014 07:43 PM
