Diagnosing a HVAC vacuum issue on a Ford F53
Mike_Schriber
The AC/heat is switching to the defroster under higher RPM conditions on my 2006 F53 chassis Damon. It actually seems to be doing it now under low throttle steady state conditions as well. Obviously a vacuum issue but I'm not finding any obvious leaks.
The leads me to focus on the vacuum accumulator but I'm not sure how to test it. I can't even figure out how to remove the lines going in and out and I don't want to break anything fumbling around. Any suggestions?
Thanks!
Mike
2006 Damon Daybreak 3276 37' bunkhouse
22 REPLIES 22
JaxDad
Glad you found the actual problem instead of just throwing silly wasted parts at it.
So much for the “ONLY” solution........
The main reason I won’t go to the stealerships is for exactly that reason, there’s no THINKING about the problem and finding the solution, it’s just throwing parts at it because a book or computer said to do that.
Thankfully the only place where such foolishness does NOT exist is in aviation, which given the price of parts is a VERY good thing.
Mike_Schriber
Found it!
I ignored the critical axiom, test like you fly. It only was leaking in recirculation mode and I wasn't testing it that way (because it was cold and I had the heat on) even though that's how I usually have it set. Found several leaks in the hose "under" the hood leading to that baffle. Easy fix with some tubing I had lying around from a previous repair.
Thanks for the feedback!
Mike
ScottG
For some reason the resevoir is not holding vacuum. There can be a leak just about anyplace but I would look where ever some kind of work has been done.
I once fixed this sympton on a car that had a battery changed. They pinched the vacuum line under the edge of the battery and it took a couple of years for it to rub though.
dougrainer
This is a common problem on Ford Class A chassis going back over 20 years. The ONLY sure fix is to install a 12 volt vacuum pump and plug the vacuum line from the engine. You will have people tell you to test this and test that and add another accumulator, and check all the vacuum lines and motors on the dash evap system. The plain fact is, the aftermarket Dash AC systems on Ford Class A's have inherent vacuum leaks and cannot overcome the engine going to zero vacuum on full acceleration or climbing hills. You can do a search for this problem on this forum and see all the silly things people are told to do, when the plain fact is, you need the 12 volt pump. I speak from over 38 years and still working on Motorhome Dash systems and YES, I have installed a few of the 12 volt pumps, even years ago when the Coach Maker paid for the pump installation when the RV's were under warranty. Doug
https://www.amazon.com/APDTY-015325-Vacuum-Pump-Supplemental/dp/B00BVQZSKO
Big_Katuna
I have heard of adding a vacuum pump to run the dash.
My Kharma ran over my Dogma.
JaxDad
Take a small propane torch and unscrew the head leaving just the valve and pipe, then slip a piece of tubing over the end of the pipe. With the engine idling and the valve on the torch open (but not lit obviously) run the end of tube along every vacuum tube in the HVC system.
When you get to the vacuum leak the engine will inhale the propane and the extra ‘fuel’ will cause the engine to speed up a little, when you pull it away it goes back down again.
It makes finding vacuum leaks super easy.
Gdetrailer
Sounds a lot like a chaffed or cracked vacuum hose, may not hear the leak depending on the location of the leak.
Most likely will need to start inspecting all of the vacuum hoses, not sure what engine you have but there are a few well known issues with vacuum lines and hoses on the modular engines which have a history of chaffing and or cracking from heat in the engine bay..
Mike_Schriber
Actually... I just unplugged the hose from the accumulator where it connects to the dash controls. The baffle for the defroster immediately dropped and the line was hissing. The engine has been off for a half hour so that tells me the accumulator is fine. It would also suggest there's no leak elsewhere in the system which makes no sense.
Any thoughts?
It could be between the manifold and the accumulator but as near as I can tell that line is fine. The other vacuum line from the manifold goes to a device with an electrical connector on the driver's side valve cover. I'm guessing this is a valve related to the PCV system and if it was bad I guess it could deprive the whole system of vacuum but I don't want to go down that road without more information.
Thanks (again)!
Mike
