Bumpyroad's avatar
Bumpyroad
dicor, in a can, can be painted on
a while back somebody posted about a source for a self leveling caulk that was not in a tube, it was in a can and could be painted on.
did a search to no avail. went thru about 100 pages of my old posts and could not find it.
can anybody steer me to it. I think I can do a nicer job of painting it on than trying to use a caulking gun which always gives me fits.
thanks,
bumpy
  • DiskDoctr wrote:
    Bumpyroad wrote:
    This is on a fiberglass roof. might have to invest in a "powered" caulking gun, assuming that those can be fine tuned to put down a steady line. just checked at Home Depot. they have a Ryobi 18 volter for $40.
    bumpy
    These guns work great! It backs off a bit each time you release the trigger, so it's best to layout what you want and put it on in as continuous bead as possible.
    The thickest I've used it with is Blackjack roof cement, which is basically the consistency of tar.
    And, yes, you can take it down to a fine bead using the proper combination of gun setting and speed you mmove over the surface. No need to pause or surge for hand pumps ;)
    I've owned one for many years and recently changed the batteries to Li-ion
    thanks for the user testimonial. sounds like a plan if I can't find the stuff in a can. would like to use a urethane type as that was recommended.
    bumpy
    bumpy
  • I was camping in tx last year and was doing calking on the roof , when I came down another camper came over and said he was having trouble calking. I told him I either put my tube in the front window or got the hair drier and heated the tube. Just make sure your tube is warm, makes life easier.
  • This is on a fiberglass roof. might have to invest in a "powered" caulking gun, assuming that those can be fine tuned to put down a steady line. just checked at Home Depot. they have a Ryobi 18 volter for $40.
    bumpy
  • Almot's avatar
    Almot
    Bumpy, I hear your pain of dealing with caulking guns. But if you need a caulk-ish substance, you have no choice but to use a gun, or a smaller squeeze-tube which apparently is not available with Dicor. And then spread it over a larger surface with a putty knife if you have to, but do it quickly because the surface starts "skinning" after a few minutes and then it doesn't adhere well to the parts that you are working on.
  • I see there was a previous thread on the Dico product, "Good Caulking". very little "substance". lots of whining that it wasn't Dicor. :)
    bumpy
  • Old-Biscuit wrote:
    Dyco 20/20 Roof Seam Sealant
    Also Dyco Dyoseal Brush-on Sealant
    (Dyco not Dicor)
    thanks, not too much information at the links I found. the 20/20 is evidently a rubber based?
    bumpy
  • Almot's avatar
    Almot
    Why? This isn't by Dicor. And this isn't for same applications. If it can be brushed on, then it is less dense than the stuff in caulking gun and may need coating twice.
  • Dyco 20/20 Roof Seam Sealant
    (Dyco not Dicor)
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 03, 2026
