gavinhickson
Aug 13, 2018Explorer
Digital to Analog Thermostat?
Good afternoon, I have a 2017 Forest River Stealth. My question is regarding replacing the digital thermostat with an analog thermostat.
It has:
(1) Dometic B59516.XX1CO Duo-Therm Brisk Air II Air Conditioner
(1) Suburban SF30FQ Furnace
It originally had a Dometic 3313192 Thermostat
It currently has a Dometic Capacitive Touch Thermostat
My problem with the original thermostat is that the furnace would stop working. I would leave the trailer parked up in Northern AZ for weeks at a time. We would set the heater to 50 degrees to keep things from freezing inside the trailer. When we’d return, the temperature inside the trailer was cold and the furnace would not be working even though the thermostat was still set at 50 degrees. Once we turned the thermostat off and then back on….the furnace would kick right on.
We took the trailer in for warranty and they replaced the thermostat with the Capacitive Touch style. We are still having the same issue. Not only with the furnace, but also with the A/C. Last weekend while using the trailer, the A/C worked fine throughout the day with the thermostat set at 76 degrees. During the night, the A/C would stop working even with the thermostat set at 76. As soon as we turned the thermostat off and then back to cool…the A/C fired right up.
So my question….Can I replace the digital thermostat with an analog version to see if that will solve the problem? Is there a direct replacement? Are extra parts required?
I called Dometic this morning and they said the analog thermostat would require 3 extra wires be run. Has anybody had any experience with what I’m trying to do? I appreciate your help. Thank you much.
It has:
