- wa8yxmExplorer IIIFor that size have you considered a Game Boy Wall Wart type? Do not think it is a switcher but at 0.3 amp who cares. It is 3 volt though. I have one I use it works perfectly with one of my Mini-Disc (Sony) recorders that also needs 3 volts and is a very very very picky eater.
- MrWizardModeratorallelectronics has all kinds of stuff
but i'm not understanding the Idea behind this one
since i know you have all kinds of meters and testers
this 3v indicator for 120vac BEGS WHY ? - Chris_BryantExplorer IINot exactly what you want, but cheap enough. The 9vdc is a wall wart, going in to a 3.3vdc regulator. Under $15 combined, and if you removed the wall wart from the case, very compact.
- KJINTFExplorerHave you given any thought to using one of the USB chargers?
I have several that ingest 115Vac and output 5Vdc at 500ma
I'm sure you can get one for next to nothing
If need be add a 5vdc to 3Vdc three terminal regulator on the output - ken_whiteExplorer
MEXICOWANDERER wrote:
Ideal unit would be a circuit board with solder tab connections. 300 ma would be plenty
Hopefully not that expensive. For power pedestal power available indication. If I have to settle for 5VDC final I'll take that.
Do you need isolation from primary power?
There are quite a few evaluation boards out there, plus lots of application notes if you are interested in designing your own.
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 22, 2025
