DIY 50 amp to 20 amp pigtail
KnowNuthin
I want to plug my tractors block heater into our 50 amp RV service for the upcoming winter monthsโ€ฆ
Our panel has 1 - 50 amp and 2 - 20 amp breakersโ€ฆ both 20 services are taken and currently used year roundโ€ฆ (chicken heat lamps, water bowl heaters etc.)โ€ฆ
What Iโ€™m envisioning is a 50 amp plug with a 3 wire pigtail connected to the common, neutral and one hot legโ€ฆ leaving the second hot leg vacantโ€ฆ
This would give me 120v 50 amp at the pigtail endโ€ฆ no?
This would be used STRICTLY for a 600 watt engine block heaterโ€ฆ
Is this a bad, terrible or workable idea?
2005 2500HD D/A CC LB 4X4 being pushed by:
2016 Grand Design Reflection 303RLS
2007 Ural GearUp Arctic
60 REPLIES 60
toedtoes
LittleBill wrote:
so do all you guys who have 15 amp circuits in your house, where your lamps are plugged in use a 1 amp circuit breaker to each individual lamp?
No, but anything that produces significant heat is put on a GFCI outlet or is connected via a surge protector with internal circuit breaker. But I admit I have a healthy fear of electricity.
1975 American Clipper RV with Dodge 360 (photo in profile)
1998 American Clipper Fold n Roll Folding Trailer
Both born in Morgan Hill, CA to Irv Perch (Daddy of the Aristocrat trailers)
wa8yxm
enblethen wrote:
Your 50 amp should be a double pole breaker.
I think it is a bad idea for what you are thinking.
I would suggest getting thin breaker with two 20-amp breakers and installing a new receptacle. Some call breakers, wafer or tandem.
The short answer is yes it would however there is a danger
The longer answers #1: You need not DIY you can easily adapt from 50 amp RV to TT-30 and from there to a common 15 outlet (Why they always make it a 15 and not a 15/20 I will never understand)
in fact...
Here you are
But I'd not do that
I'd use a box that lets you put a 15 or 20 (Depending on the outlet) breaker in with the 15/20 amp outlet. You need to protect the smaller wireing
Your proper adapter would look like this
50 amp plug & pigtial== Box with 20 amp breaker---15/20 amp outlet---Tractor
Or use a 15 amp breaker and a 15 amp outlet
The breaker need not be teh "Square D" type you can use a "push to reset) if you have a box with enough room.
As you surmized one black (or red) wired is NOT connected.
LittleBill
time2roll
enblethen wrote:
The lite wire becomes a fuse if you use the 50 ampere's circuit. Failure in the heater could cause wire to melt down and create a fire situation.
This could happen on a 15 amp circuit also.
Probably #18 wire in the cord.
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
time2roll
Grit_dog
Navigator
Navigator
KnowNuthin wrote:
My original idea is officially axed... somewhere in the back of my brain having 50a running through an extension cord didn't seem like a good idea,
Mitch's idea works too... I already have the 50a - 30a dogbone...
Remember, you're not automatically pulling 50A through your ext cord. You only have the ability to, in the scenario you mentioned. If the "load" only takes say 2 amps, or whatever, that is what the cord "experiences." The danger mentioned is the "potential" to draw the theoretical 50A of current and not blow the breaker, thus heating up and damaging the weakest link in the chain.
There are a few options, not entirely clear without seeing your sub panel, but seems the easiest and safest no brainer is get a 30-20A pigtail and not ever touch the hot side of the box.
toedtoes
KnowNuthin wrote:
My original idea is officially axed... somewhere in the back of my brain having 50a running through an extension cord didn't seem like a good idea, but, hey... I'm not an electrician...
I like the options presented by Dutch and Toed... it appears both of them are limited to 20a ... a much better solution...
One is more simple, the other offers the ability to close the front of my 50a box...
decisions... decisions...
Any of them will work. I like the one I posted simply because it has internal circuit breakers. And it's only one connection versus the two connection points with the 50-30 to 30-20. But that's just personal preference.
I'd consider potential use off season for the adapter. Would the 50-20 or the 30-20 give you any options for use when RVing?
Cummins12V98
Dutch_12078 wrote:
Generator/RV 50 Amp 125/250-Volt NEMA 14-50P Plug to Household 15 Amp 5-15/20R T-Blade Connector RV ...
That will do the job but I would rather have what was mentioned earlier as this will give you the 30A/120V option.
"You can buy what you need off the shelf. Get a 50a-30a adapter. Then get a 30a-20a adapter."
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
KnowNuthin
pianotuna
Nomad III
Nomad III
Hi,
Build a 50 to 20 break out box. Have a 15 amp circuit breaker "in line" (or in the break out box.
My own break out box has one 30 amp (l1) and two 20 amp (l2) breakers with plugs. It is, of course, unbalanced if it is fully loaded. (i.e. 30 amps one leg, and 40 amps other leg).
Regards, Don
ktmrfs
there is a potential safety/fire issue. I'm going to assume the cord to the block heater is a 12ga cord. Now you hook this up and end up with a low resistance high current draw. The breaker won't trip till it exceeds 50A, so you could end up with 50a through a 12ga cord, NOT a good idea, it would get quite hot, maybe even hot enough to melt the insulation and start a fire.
you want the upstream breaker in this case to be a 15A or 20A breaker.
2011 Keystone Outback 295RE
toedtoes
Would this work for you? It has a built in circuit breaker for added protection:
50amp to 4x 15/20amp adapter
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
MitchF150
You can buy what you need off the shelf. Get a 50a-30a adapter. Then get a 30a-20a adapter. People do this all the time when plugging in their 30 or 20a only rigs..
Difference is that the rigs themselves will have their own 30-20a breaker, so it's still protected to that amount.
If you just plug right into the adapter with the 600w heater, it'll still be connected to the 50a breaker. It'll work just fine, just not pop until it exceeds the 50a breaker if something grounds out for some reason.
Good luck! Mitch
