โMay-11-2023 07:54 AM
โMay-14-2023 03:20 PM
โMay-13-2023 07:17 PM
brianosaur wrote:
Retirement is about 5 years away and the TT we have will be replaced with a more semi-full time bigger rig when boondocking will be more prevalent.
โMay-13-2023 08:45 AM
โMay-13-2023 07:24 AM
Bobbo wrote:
WFCO converter/chargers are KNOWN to not get to 14.4v. Replace it. There are several good ones. I, personally, prefer the Progressive Dynamics PD4655V. It should be a direct drop-in replacement.
โMay-13-2023 05:37 AM
โMay-12-2023 06:30 PM
brianosaur wrote:
It is a WFCO WF8955PEC
The manual has some weird statement saying it reaches 14.4v but a multimeter will only show 13.6v
โMay-12-2023 06:25 PM
brianosaur wrote:That is a bunch of BS to hold the claim all is fine when the converter has a poor design that simply fails to work as expected.time2roll wrote:
No mention of the converter brand... however if the battery voltage never gets to 14.2+ volts it will be a slow charge to 100%. Could take 8+ hours from low to near full charging at a common 13.6 volts.
โIf the output current reaches its maximum (normally caused by a discharged battery),
this will cause the converter to go into Bulk Mode, which means the target output voltage
will change to 14.4 VDC and a timer will start. Although the converter is outputting 14.4
VDC, you will not be able to read that on a voltmeter due to the voltage-current
relationship.โ
โMay-12-2023 06:02 PM
โMay-12-2023 11:20 AM
โMay-12-2023 09:42 AM
โMay-12-2023 06:44 AM
โMay-12-2023 05:59 AM
โMay-11-2023 11:58 AM
โMay-11-2023 10:20 AM
