Doing something wrong with winterizing
Cougargm
I've been winterizing my own Class Cs for the past ten yrs...but the past three yrs I've apparently had a problem with the shower. Everything else- spigots, toilet, water heater- have been find when I de-winterized. But several yrs in a row I've had to replace the shower spigot. One yr it was leaking, and this yr the vacuum breaker had a small leak. I didn't have these issues the first yrs but it's been a few in a row. Maybe it's coincidence but I'm wondering if I'm doing something wrong with the shower spigot.
9 REPLIES 9
wa8yxm
I used the dry method the 2nd year. First year with Pink Stuff I had that same issue with the vacuum breaker.
The vacuum breaker is a rubber disc, that's all you can clean it and turn it over and it will work again
AllegroD
Cougargm wrote:
I actually take the shower hose off after making sure the red stuff flows through it.
With all you do it sounds like age is catching up with you . . er . . your rig.
Lantley
Dick_B wrote:
It seems to me that if pink stuff flows out of every orifice you can't go wrong.
X2
Dick_B
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
Boon_Docker
schlep1967 wrote:
Are you using RV Antifreeze or just blowing air through the lines?
schlep1967
2021 Chevy Silverado LTZ 3500 Diesel
2022 Montana Legacy 3931FB
Pull-Rite Super Glide 4500
Cougargm
BarabooBob
After winterizing, I remove both shower heads/hoses to keep anything from pooling in the hose. I cover the outside shower hose hookup with plastic wrap held in place with a rubber band. I know it looks pretty redneck, but it works. Oh, I am a redneck.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
sammytoo
Are you leaving the shower valve open and the shower head lower then the valve? If not enough condensation can collect to cause a problem.
