Domestic 3804 Not Cold On Gas
dano73
I have a 1990 dometic that works fine on electric, but barely works on gas. A few weeks ago it lasted about a day on gas, now it melts down within a few hours. The cooling unit is spotless, I mean no rust, barely looks like it was ever used. The regulator was replaced, the pressure at the burner is 12, the burner is spotless, no rust in it. The flame is a strong blue, never goes out , and the chimney temp, checked with an IR thermometer is the same wether on gas or electric. The chimney is clean as far as I can tell, I've blown air up it, and using a mirror, looks clean inside. I have cleaned the orifice with alcohol, made no difference, and the burner is in position directly under the chimney. I have owned this for about 4 yrs and it never really worked well on gas, now it's really getting unuseable, unless it's plugged in. Oh and all the other gas appliances work fine. What's left??the board??
15 REPLIES 15
SidecarFlip
Blowing air up the chimney don't work. You need to pull the baffle in the chimney from the top and clean it and run a bottle brush DOWN the chimney. I bet it's sooted up.
I'm sure Biscuit will chime in shortly.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
