mrshane
Dec 26, 2023Explorer III
When you see it lit up, make sure to check the gas system to see what the source of the problem is. There are some possible causes like The igniter is faulty or not getting enough power. You can test the igniter with a multimeter or replace it if necessary. The gas valve is stuck or leaking. You can check the gas valve for any obstructions or leaks. Check the gas line for any blockages or loose connections and clear them. If none of these solve the problem, you might need to replace the control board or the entire refrigerator. Better to call a technician
Having RV issues? Connect with others who have been in your shoes.24,198 PostsLatest Activity: Feb 12, 2025
