billclark's avatar
billclark
Dometic 3313189.000
Just replaced my old control board with dometic 3313189.000 due to having airconditioner problems. Turned out the board was problem so I replaced it. Now, when I switch my thermostat to furnace, the furnace relay starts buzzing, furnace fan kicks on and relay still buzzes with no ignition. I am new to all this travel trailer stuff and would appreciate any help. Thanks
1 Reply
  • 1. Always post Year Brand Model of RV
    2. ALWAYS post model of appliance (Dometic AC model)
    3. Post TYPE of wall tstat. Dometic has almost 8 different models.
    4. We will assume the Single zone tstat with just 3 wires to the tstat. Correct? That is the tstat that your control board uses.
    5. I will bet you have not connected the wires at the new control board correctly. The 2 blue/white wires go to the furnace. Doug
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 03, 2026
