MDavisNelson's avatar
MDavisNelson
Dometic AC Fan Not Working
The AC fan in our new to us 99 Class C Motorhome doesn't work. We have replaced the fan motor, and the start and run capacitors. The AC runs fine, the compressor gets cold, the fan just doesn't kick on with either the on or auto button. Does anyone know what the issue might be?
AC Specs:
Dometic 57915.622c
Thanks, Margot
  • I suspect your thermostat is bad.
    It sends voltage on separate wires to the compressor and fan.
    Try changing the "auto/always on" fan switch and see what happens.
    Could be a loose wire in the thermostat.
    Richard
  • Is there power going to the fan motor when it is supposed to be running? Perhaps you have a bad relay.
Having RV issues? Connect with others who have been in your shoes.24,372 PostsLatest Activity: Mar 30, 2026
