Hondavalk
Sep 17, 2014Explorer II
Dometic AC turning on & off
I have a 2013 Crossroads ST29SS. When its real hot and I have the AC unit set in the ducted position the second it stops one cycle it starts right back up. If I open the direct vent it operates normally. The air flow seems strong at all the vents and if the temps are moderate it runs fine. There doesn't seem to be air blowing on the Stat when in the ducted position so I can't figure whats the reason. It does cool the unit fine. :h
