Chuckf1
Aug 05, 2015Explorer
To Chris Bryant - Dometic told me there is none hear. I trusted her and didn't follow-up. There are several mobile, doometic certified, techs and one will come our next Friday. Thank you!!
Macrosill and RoyB - We are on 50amps and drawing 15-20 amps per unit. The readings don't fluctuate so it is clean.
MidnightSadie - Good suggestion. Swapped breakers form other a/c unit. Same results.
Also, I'm hearing rumors that Dometic A/C of my model installed a bad bath of controller boards. Another possibility. Hope the tech can replace them as well.
Thanks to all for your help.
Having RV issues? Connect with others who have been in your shoes.24,210 PostsLatest Activity: Mar 04, 2025
