Dometic CF40 (CoolFreeze) acting up badly
Teeshot1939
The portable 12v/120v Dometic refrigerator/freezer will not stop freezing everything regardless of where I set the temperature. It is 12 years old. Dometic says it "COULD" be the control board. Not sure if I can find a control board. A replacement model for a similar unit is over $900. How would you proceed? Thanks.
1 REPLY 1
Teeshot1939
Turned out the be the thermister...not the control board. Thanks everybody!
Type a product name
