So i have been doing some digging.. I found a part list online at youngfartsrvparts . com/pages/dometic-dmc4101lss-product-id-936100408-parts-list its reference 289 for the part number. I called a local dealer in Yuma,, Rv World and they were able to order it for me with it takeing about a week to get..
I have also been chasing down lead on teh fan motor as well..
when i put this number in google some stuff on amazon come up .. seems this is a popular evap/ freezer fan motor for other units but not this exact one.. the plugs are different , this is a small 3 pin adn the shaft is 2" long from the hub.. I found a couple that have close to same 2000 RPM but the shaft if shorter.. so going to see what i can do to retrofit a cheaper way to fix these things.
Dometic has the parts fro this thing locked down TIGHT.. all i need is a fan motor but i gotta get all the other stuff.. stuff you have to remove to get ot fan motor.. go fricken figure.
