Dometic Freezing up
mick2268
OK so I have a 2014 29'Cougar with a single 30 amp unit. 1st coupe of years it worked fine, but last year froze up regularly even when on High and not pushing it through the ducts.
I had a power surge burn out the brain in it summer before last. I replaced it, and noticed the freeze up issue start after that. I think I may have bumped or moved the freeze sensor. Can anyone school me on how to set that back in the correct place and position?
2 REPLIES 2
YC_1
Have you cleaned the coils? I mean both sets of course.
H/R Endeavor 2008
Ford F150 toad >Full Timers
Certified Senior Electronic Technician, Telecommunications Engineer, Telecommunications repair Service Center Owner, Original owner HR 2008
shastagary
try page 42 see if it looks like yours Dometic service manual
