jrg3170
Jul 09, 2018Explorer
Dometic fridge shuts off overnight (propane mode)
I have a two year old Dometic refrigerator that won't stay on in propane mode. Electric mode works fine.
When starting up the fridge makes a bunch of clicking sounds, the burner momentarily engages then goes out, then more clicking, then burner, and so on for maybe 1-3 minutes until the fridge gives up and the "check" light comes on.
If I keep resetting the fridge, maybe 4 or 5 times of this then the fridge will eventually engage and work fine. It will work throughout the day and into the evening. However, when I wake up in the mornings the “check” light is always on again. Repeat above and it starts working again.
This makes me think maybe air is getting into the gas line overnight somehow? Or maybe it doesn't like cold temps (I was in CO at 9K feet, 70s in the day and 40s at night). I don't think there is a leak as I just returned from a five day trip where the gas line was open the entire time and I had plenty left in the tank afterwards even with consistent usage.
I took a video of the burner trying to engage, see here: ***Link Removed***
Thoughts? Should I try replacing something?
