dougrainer
Feb 21, 2021Nomad
Battery is not an issue as long as the Power Converter is operating and producing 12.9 volts and higher. A DEFECTIVE battery should be replaced as come Converters do not operate well with a BAD LOAD(Load is the battery). A defective battery should NOT be installed in a Trailer while towing. The Emergency Brake Away will not work with a bad battery. Doug
Having RV issues? Connect with others who have been in your shoes.24,382 PostsLatest Activity: Apr 23, 2026
