Dometic Frig Model RM2652 not working.
chiefward
The frige is not working in stationery RV. Check light on front control is not on. Both electric and gas heaters are working. No indication of refrigerant loss. fuses check ok. Suspect control board is bad but don;t know how to check it. Any suggestions will be greatly appreciated.
2011 Fun Finder by Cruiser RV, model X210WBS
2017 Ram, 1500, Tradesman,
10,000 Equal-I-zer hitch
6 REPLIES 6
mchero
"Easy fix" until you figure out how your getting current fridge out and new fridge in. Having to go thru a window is not fun!
Keep us posted on your project.
Robert McHenry
Currently, Henniker NH
07 Fleetwood Discovery 39V
1K Solar dieselrvowners.com
2005 Jeep Grand Cherokee
Prior:1993 Pace Arrow 37' Diesel
chiefward
Easy fix. I;m going to replace with household type....
dougrainer
If the freezer plate does not get cold at all, your Cooling Unit is toast. Doug
Old-Biscuit
ON for 'several days' does NOT bode well
chiefward
Old Bisquit: Fridge does not cool at all: that's after being on for several days. The flu get hot from both gas operation and electric. Will try your suggestions. Thanks for responds..
Old-Biscuit
Not working but electric and gas working......:H
Do you mean no cooling?
How long has fridge been ON?
Is freezer getting cold at all?
How do you know electric heater element is working?
What does gas flame look like
*Strong Steady BLUE flame that reaches up into flue opening???
Unplug thermistor leads from lower control board (P2 connector..left side)
Run fridge for 12 hrs then check freezer/food compartment temps?
IF temps are not cold.....
Unplug electric heater element leads from lower control board
Plug leads DIRECTLY into a known working 120V AC Outlet
Run fridge for 12 hrs.......if it cools ....bad control board/if it doesn't cool----bad cooling unit
