rsg33
Mar 06, 2007Explorer
The unit is LP/110V only. Dometic uses the same cooling unit (with two pockets) for the two-way and three-way double-door fridges. I'll get closer shots when the cooling unit is removed from the box tomorrow.
The main thing to note is the element is NOT a 354W and has never been changed, so I'm not sure about the validity of the higher wattage/over-heating issue. It appears, judging by this unit, that a defect can show up even with the standard 325W element.
