โSep-21-2019 09:13 PM
โSep-26-2019 09:28 PM
โSep-26-2019 09:07 PM
happy2rv wrote:cannesdo wrote:
Ok, so its been running on gas. Yes, it was on AUTO just checked it -- 30 min. after putting the new fuse in and the coils aren't really warm and the heating element is luke warm. Not a good sign.But we know the heating element can fire up because it fires up on gas, yes? So if it's not the heating element or the board...?
Electric heating element has absolutely no relation to gas heating. When operating on gas, a flame heats the ammonia solution in a boiler. When operating on electric, there is no flame. The electric heating element heats the ammonia solution in the boiler instead of the flame. The refrigerator will work on gas without being plugged in because the control board is powered by 12VD from the battery. I wouldn't judge the refrigerators operation based on the temperature of the coils, especially after a short period of operation. Its the temperature of the boiler that's important. Google RV absorption refrigerator cycle to see how the system works.
See this youtube video for instructions on testing the heating element. I suspect you have a bad heating element, but the only reasonable thing to do is test it. The heating elements run between $45-145 but it could still be other issues. Troubleshooting by replacing parts one at a time without testing them can be an expensive proposition.
โSep-26-2019 08:56 PM
โSep-26-2019 08:07 PM
dougrainer wrote:cannesdo wrote:
I am so confused. The fridge is running just fine on electric now -- but it is not plugged in!!! What's up with that??? Is it running on battery power? It is definitely set on electric and not on gas.
I am so confused.
YOU are confused?? This is like saying I am watching TV and the TV is not even plugged in. It must be on LP if not plugged in. You need to post Year/Model of RV and Model of Refer. IF it was on 12 volt(3 way refer) and had a 12 volt element, it would not cool adequately. IF you have it on AUTO, it WILL go to LP if the unit is NOT plugged into 120 power. Doug
โSep-26-2019 05:48 AM
I am so confused.
โSep-26-2019 04:52 AM
I am so confused.
โSep-25-2019 10:46 PM
โSep-24-2019 07:58 PM
โSep-22-2019 03:26 PM
cannesdo wrote:
Update: Plugged my blow dryer into the fridge outlet and it works. Plugged it in set to off but (coincidence?) the fridge made a sound like it was powering on when I plugged the blow-dryer in. That was weird. ?
Now...youtube video about how to test the fridge element...
โSep-22-2019 02:27 PM
โSep-22-2019 01:27 PM
โSep-22-2019 01:25 PM
No...just one fridge...neighbor's. An RV tech did look at it and said it was a problem with the "electronics", think he meant the board so I'd like to help her and save her the money. The board I ordered is returnable. The fridge has an element too? I'll google...she left it to spend the winter in Mexico. The trailer wasn't moved. And it did snow one day so it could have gotten pretty cold. Don't know if that was enough to affect the ammonia.
ANYBODY that states, "it is a problem with the electronics" means they are NOT a qualified RV Tech and are just Part Changers. They should be able to state WHAT part is the problem if they are qualified. IF that person did not actually look at the refer, then do NOT trust what he states. Doug
โSep-22-2019 12:07 PM
โSep-22-2019 11:35 AM
