jammeusel's avatar
jammeusel
Dometic Refrigerator NDR 1292
Dometic Refrigerator NDR 1292 switched over to gas with shore power supplied to the refrigerator.
I checked the power at the receptacle and all is good.
jammeusel
  • 120VAC Hot J5 Terminal on Circuit Board
    120VAC Neutral J6 Terminal on Circuit Board
    120VAC 5A Glass Fuse...just above J5
    Fuse blown...good chance ONE of the elements is bad
    J8 Terminal...120VAC Hot to element (Black Lead)
    J7 Terminal...120AC Neutral from element (White Lead)
    The element leads are wired is series....2 leads to 1 lead for terminal on circuit board
    Bad element.replace both
Having RV issues? Connect with others who have been in your shoes.24,189 PostsLatest Activity: Jan 19, 2025
