bigfootford
Jun 29, 2023Nomad II
rvman69 wrote:
There is only one place on this board that the gas valve and ignitor power can plug into. The 12v power wire goes from the control board to the gas selenoid valve to the ignitor. I guess I should check and make sure it is not loosing voltage from the selenoid valve to the reignitor. My board is 385 04 15-01 if I replace it with a Dinosaur board does it have the reignitor built into it? I was told you cant get a replacement reignitor. Do I use the original thermocouple and ignitor? I dont want to buy a new board if the reignitor is bad and cant be replaced. Thanks
The Dinosaur board for the 2652 does not have the igniter built in.
Wow, OEM igniter is no longer avail. This is the only place I have found it...
https://www.ebay.com/itm/164674934043
Make sure that you have yours wired up properly..
Look at this simplified diag at Dave's Place and make sure that the wire from the solenoid to the igniter + then to the control board is in the proper place... AND the ground wire goes to ground!
You should hear the gas valve turn on for about 3 seconds if the control board is working correctly. That signal turning on the gas valve is the same signal that tells the Igniter to start firing!
You should see the 12vdc at the wire on the gas valve as you turn on the fridge in the gas mode! One wire is - negative and the other is the signal 12vdc.
http://dave78chieftain.com/2807tronics.html
Jim.
Having RV issues? Connect with others who have been in your shoes.24,216 PostsLatest Activity: Mar 15, 2025
