philo111
Nov 06, 2016Explorer
Electric Power Question
I have a Camper Box Truck with a 14' box. I also have a 10,000 BTU portable A/C that uses 1200 watts / 10.8 amps).
I would like to run the A/C for several hours without a Honda type gas generator.
I was thinking:
I could upgrade the Truck Alternator to one that produces
100 amps at idle.
Get a good quality Deep Cell Battery that holds 200 amps.
Get a 3000 watt inverter.
Plug in the Portable A/C.
Start the Truck and just let it idle for hours when the A/C is
on (the engine does not over-heat).
Would this work?
Thank you for your thoughts!
I was thinking:
100 amps at idle.
Would this work?
