TWH99
Sep 13, 2017Explorer
Thanks TimetoRoll and Bigg Al,
My application is a Mobile 20 foot travel trailer that I will travel & l live in full time. I would like to run everything on battery, re-charged by solar Photo Voltaic cells. I will have a generator (Honda EU2000i) for back up. I will have a fixed, non-expandable physical space for the battery bank in the trailer. The wire run between battery bank and 3000 watt inverter will be less than a foot long and wires from solar panels to the battery will be relatively short also, but the longest less than 15 feet long.
1. Are these wiring lengths going to be helped significantly regarding resistance with the 24V system? I think I prefer the simplicity of a 12V battery bank for charging/operating the devices I have that can be plugged in to my 12 volt receptacles, and by-passing the inverter which uses power and produces heat.
2. I will run a 5K BTU window unit air conditioner that will have a start up surge of about 200 Amps (12 volt), will run with compressor on using about 40 Amps (12 volt). With 600 Amp hours of Lithium, 80% useable = 480 Amp Hours, I should be able to safely run the small Air conditioner for 8 hours. Will running approximately 500 watts continually for 8 hours through the Inverter be “hard” on it, shorten it’s life, increase energy consumption as it heats up.? Do I need to worry about any of this or is it only a concern when the constant load is much closer to the Inverters regular capacity. In my case if I had a high quality 3K Watt Inverter (3500 surge for 5 seconds) could I run it continuously at a 2000 or 2500 watt load for 8 hours without it skipping a beat or shortening it’s lifespan?
3. Recharging the 600 Amp hour battery pack. The Inverter/Charger combo unit says in it’s shortened spec sheet: Charger-125AC Efficiency – 88%. I’m guessing the efficiency relates to the Inverter and means for each 100 units of Battery power it draws it only converts 88 equivalent units to the device being powered…is that correct? What does the 125AC mean regarding the Charger? Does it mean it can pump in 125 Amp hours back into the battery each hour assuming the power supply can keep up with that? If not what does it mean 125AC.
4. As related to #3 above, if I am using a small Honda EU200i generator to recharge the battery bank (assume no PV solar panels working) and no draw on the battery bank, and the Amp hours on the battery has been drained down to 20% or 120 Amp Hrs, roughly how long will it take to charge the battery bank back up to 600 Amp Hours or what is the hourly rate of recharge in Amp Hours. I’m not sure what the relevant numbers are on the Honda spec sheet that relates to recharging a battery but one of these must be it. AC output – 120V 2000W max. (16.7A) 1600W rated (13.3A). and DC Output – 12V 96W (8A) and Receptacles 20A, 125V Duplex
5. Lastly, please confirm if this recharge calculation is correct for Solar Panels. A clean, properly angled, 100 watt panel, in 70 degree weather will be about 80% efficient during the peak hours equaling 80 watt charging rate per hour which equals 80W / 12V = 6.6 charging Amps per hour or 10 hours of full sun to put in 66 Amp hours into the battery bank.
Thanks to anyone who has stayed with me and is willing to answer some or all of my questions.
Tim
Tim
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
