beachdrmr3369's avatar
May 28, 2020
Electrical Issues on new travel trailer
Hello,
I'm a new owner of a 25' travel trailer. So I am completely not up to speed on the electrical. A situation happened when I was hooking it up to the meter panel for the first time. I was not told that the trailer should be hooked up to 110. The rv site is set up for 220 hookup. The plug on the trailer is also set up for the 220 hookup as well. So when I plugged it in, there was a loud pop and smoke came out of my tv and the control panel inside the trailer. I quickly unplugged it. But then some of the lights, microwave and tv didn't work. I called the dealership I bought the trailer from and they informed me that the trailer is 110 and not 220. Very frustrated at the moment. Then much later there was another pop and then the microwave, A/C and tv turned on. But it appears they were only running on the battery. Because now everything appears very dim which means the battery is losing power. So is there anything I can do to figure out this problem I'm having? If the items came back on, can I assume it didn't fry them? Please help! Thanks!
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 23, 2026
