Side note, I very recently
Took mine all apart
Cleaned and used Deoxit on all the wiring connectors and pins
Took the wall control thermostat box out
Open it, and cleaned the board connector
Removed the sensors from the walls and cleaned inside with plastic safe electronics cleaner
To remove dust , cooking residue etc.. From the tiny thermo resistor inside, ( tiny little blue thing )(thermistor)
This is a 97 Fleetwood Bounder
And the Intellitec control is working better now, than it has in the past 3 years
This thing is old tech by today's standards, probably designed in the late 80's
I learned quite a bit from that video I posted a link too, glad I remembered it
Hope this helps you
I can explain it to you.
1997 F53 Bounder 36s
