punomatic
Apr 16, 2018Explorer
MrWizard wrote:X2 The TV menu should have an audio section that allows you to choose "(TV)Speakers" or "Audio Output." The audio output may be component (red and white cables) or optical (special fiber optic cable) or it may be a 3.5 mm stereo (earphone) plug. As one poster said, check for a cable from the TV to the surround sound amp. There should be an answer that allows the TV sound to go through the surround system.
check the TV sound/audio menu settings, for and output setting
