3_tons's avatar
3_tons
Jul 15, 2023
EPever Solar Charge Controller
A friend has a EPever Tracer 100 amp MPPT Solar Charge Controller model 10415AN…
Problem is that try as we might when trying to change a given charge program parameter on the Advanced user menu, it will not hold any revised program changes…
Thanks in advance,
3 tons
  • 3_tons's avatar
    3_tons
    Thanks for the tip, FWIW I passed it along to the poor fella - said he’s calling EPever in the morning…
    3 tons
  • try removing all power to the controller. Wait ten minutes. Then monetarily short out the inputs and outputs from the controller (no power on) to discharge any capacitors in the controller.
    Now apply power from the battery bank, then add solar.
    Attempt to set up the parameters you want.
    I hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,242 PostsLatest Activity: May 09, 2025
