http://www.mpja.com/05-31-16.asp?r=386312&s=2Stock No: 32886 RL
$10.95
Availibilty: In Stock Units: 197
This is the relay I used for Quicksilver. Two relay COILS can be connected in series for 240 volt operation. EACH relay contact is rated for THIRTY AMP continuous service. One relay can be used for 30-amp shore power/generator auto transfer. Two relays can provide dedicated 30 ampere 240 volt service. One contact EACH relay for neutral. Breaker EACH relay neutral for 30-amps.
For X-tra heavy duty service I used double relays for 30 amp shore power.
Compared to most relays I have seen in modern motorhomes these guys are light-years superior in capacity and longevity. Contacts are silver-cadmium flashed, and connections are flat blade screw.
The price is one-third to one-fourth that normally found.
The fishing vessel Kelley II, uses EIGHT of these relays for high amperage 3 phase 4-wire, shore / generator power.
