John_Burke
Mar 16, 2022Explorer
You may want to try an aftermarket electric fuel pump to help figure out if you have a in tank fuel pump issue before spending time and a fair amount of money for a new pump.
There must be a rubber line somewhere, by the filter or between the frame and the motor. The fuel filter below the seat would be a good place. Just put an electric fuel pump in line where the filter is and run it off a jumper wire, extra battery or a battery charger. If it is all steel line you can put a piece of rubber line over the steel line and clamp it on.
You can get a pump from Amazon from 12.00 to over a 100.00. just get a cheaper one.
This way should be a lot easier diagnostic tool than dropping the tank and putting in a expensive replacement pump.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
