pianotuna
Mar 31, 2014Nomad III
Fan Folly
Hi,
As many folks here are aware, I regularly rv in sub zero temperatures. I've made quite a few mods to allow me to do so in relative comfort.
One of those mods is a pair of fans that are thermostatically controlled, to replace the return air grill on the furnace. That lets me heat electrically without freezing the fresh water system. It also sends air through the furnace duct work.
Last night I was monkeying around in the kitchen and by accident bumped the switch. This morning--frozen lines to the shower and toilet were the result. (They have some nerve calling this a four seasons rv--it was only -19 c (-2 f)).
I decided to see what would happen if I simply turned the fans back on. Within the hour, the shower was operational again, and the toilet followed at about the 80 minute mark.
It did "spur" me to put in a screw--so that the fans can be run on low, or high, but that turning them off is not going to happen again.
Here is what the fans look like:
![](http://ecx.images-amazon.com/images/I/51YaTS8wd8L._SX300_.jpg)
