campinrooter's avatar
campinrooter
fifth wheel rails
Do all fifth wheel rails have the same specs as far as hole size and spacing of the holes I am asking this because I have a 2007 Silverado 2500hd short bed moving up to a 2016 3500hd long bed want to use my existing hitch but they say the brackets are different to hook to the frame. I found the kit for the truck just wondering if the hitch will fit these new rails. Any opinions on this Thanks
1 Reply
  • You didn't specify what hitch.
    I currently have a B&W companion that requires a goose-neck mount. If I change trucks, it most likely will require a different under bed mount.
    For something like an RBW little rocker and many other brand hitches which use 2 inbed mounting rails, the only thing that would need to be changed would be the frame L brackets.
    I have welded the L bracket to the frame and then when changing trucks have used a grinder to cut the welds so I could reuse the bracket on the new truck.
    As for your question, not all hitches will fit all mounting rails.
    You said you found the kit for the truck. If the kit for the truck was for the hitch you have it should work.
Having RV issues? Connect with others who have been in your shoes.24,330 PostsLatest Activity: Oct 30, 2025
